configure ospf add virtual-link
configure ospf add virtual-link router-identifier area-identifier
Description
Adds a virtual link connected to another ABR.
Syntax Description
router-identifier Specifies the router ID of the other end of the link.
area-identifier Specifies an OSPF area.
Default
N/A.
Usage Guidelines
A virtual link provides a logical path between the ABR of the disconnected area and the ABR of the normal area that connects to the backbone. A virtual link must be established between two ABRs that have a common area, with one ABR connected to the backbone. Specify the following:
  • router-identifier—Far-end router interface number.
  • area-identifier—Transit area used for connecting the two end-points. The transit area cannot have the area identifier 0.0.0.0. and cannot be a stub area or an NSSA.
The following command configures a virtual link between the two interfaces:
configure ospf add virtual-link 10.1.2.1 10.1.0.0
Platform Availability
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
